- 31 Jan 2012
- Droitwich, UK
Hi!
Is there any way to have voltage scale back when idling this CPU on this chipset when overclocking? I've managed to get a stable OC of 4.7GHz at 1.3v and 2.2v VRIN/1.1v ring voltage. Temps are fine (24c idle, up to 60c at load) but I notice as the voltage is manually set it doesn't scale down when the CPU is not being utilised heavily. I know there's the option to use voltage offset but from what I hear it's not that reliable in the sense that it can lead to more voltage being allocated to the CPU than it requires under load. Is there another method available to allow this? After finding the stable overclock I turned EIST/C3 back on but they don't seem to impact voltage. I know Asus motherboards have a dynamic voltage setting but no such luck on this mobo .
It may well be the case that I won't be able to do this with my current setup and I can live with that considering I have good temps, but any suggestions would be appreciated.
