Ok, I have an i7 930, when it runs at the stock 2.8GHz speed, it decreases both the multi and the voltage when it is in idle. However, when I then overclock it to 4.2GHz using 1.4V~, enable SpeedStep, C1E and C-State, the only thing that decreases is the multi, the voltage stays fixed at 1.4V. Is this normal? Is there a way to make the voltage drop as well even with an overclock?
I have an ASUS Rampage III Extreme btw.
Thank you.
Thank you.
