- 6 Nov 2002
We are currently trying to install a new version of Dynamics CRM on a new server. We are pointing it to a database on another server (SQL 2005/Server 2008 R2). When it does its first set of checks it comes back with the error
"The instance name must be the same as computer name"
Now from a quick google it looks like if you installed the SQL server, then renamed it, it can cause this problem. I have ran both the commands below
sp_helpserver
SELECT @@SERVERNAME AS 'Server Name'
Both are showing the correct computer name. To me it sounds like this isn't the issue. We would have renamed the server BEFORE installing SQL (it is an early step in our server deployment checklist).
Anyone else got any ideas? The port is open and I can query the machine fine from SQL Management Studio. We are running on a non standard SQL port and the SQL Browser service is disabled, could this be the issue?
sp_helpserver
