I am trying to get a Dynamode BR6004 working with my grans NTL broadband.
When I started setting it up they had there broadband modem connected to there pc Via usb so i connected it via Ethernet to check that works , and it did.
I plugged the ntl modem into the to there DSL router and did clone MAC the problem is the ntl ethernet light did not light up after shaking the cable around i eventually got it to light up.. so possibly a faulty connection.
Anyway i finally got it to light up and the MAC copied over. But when its connected via the ethernet the NTL box the other middle lights do not light up and no WAN details show in the routher control panel.. But the Routers wan light stays on.
I tried powering them both down and eventually i got it to work until i repowered them up using the same settings it did not work.
Any ideas why this is not working , i am starting to believe it due to a faulty Ethernet adapter on the ntl box or am i doing something else wrong?
