- 14 Feb 2008
- Cheshire
Oh so i decided to load this up again on PS2 to have a little fun. I've got most of the 4th weapons for the characters, however i don't have the 4th weapon for Zhao Yun. The weapon i'm after is apparently called "Fierce Dragon".
Now i have followed a guide i found over the internet that says;
Stage: Chang Ban (Liu Bei’s Forces)
Defeat Xiahou Dun, Zhang Liao, and Zhang He. In addition to this you must also wait for Cao Cao’s reinforcements to arrive (Cao Cao arrives at the 80 minute mark) and for Liu Bei will say, “Cao Cao, so you want to end it here at Chang Ban?” (occurs at the 78 minute mark); after this happens fight anyone around Liu Bei with Zhao Yun causing a cut scene in which Yun tells the enemy soldiers not to harm his lord. (This event can not be triggered by all characters, only Zhao Yun and some other Shu officers and cannot be triggered if Liu Bei has already reached his destination by Liu Qi’s ships). You must finish everything before Liu Qi arrives with reinforcements and the requirements may be fulfilled in any order (the supply team arrives after completion). It is suggested that you defeat Zhang He last (so you are close to the supply team).
Now i have tried this approach and i did not suceed on getting the cutscene between Zhao Yun and Liu Bei. Is thhere a specific way of doing this or have i missed something out? let me know if you have this weapon or know how to get it, cheers!
