?Can someone make trust work with my username please?
Thanks.
Yes, because it's done through OcUK. If you're emailed through Trust you get an email from [email protected], saying:Is it to prevent spammers sending you e-mails or something?
Please find below a message from "username", please note any reply to this member should be addressed to "user's email address".
Because I have the ² in my username, it won't let me log in and says my username can't be found.
Thanks.
Because I have the ² in my username, it won't let me log in and says my username can't be found.![]()
Username not found.Yep you have it set up, try logging in with this Viper� copy and paste job.
HahaViper² clearly cannot be trusted.
I wouldn't disagree.Viper² clearly cannot be trusted.
Username not found.
I think it used to work.. but then stopped for some reason.
