E-steps
14 Feb 2023
Scotland
I rercently tried to calibrate my E-steps.
Using this method :-
Default was 93 after a few iterations found the best E-step was 94.7 (I think, hard to remember).
Put this new value into e-steps, no noticeable difference, but did give peace of mind.
However on power cycling (switching it off and on again)the printer E-step value had reset to 93 again.
Does the Ender 3 Pro have no memory and has default settings on some sort of EPROM or do I have a lemon.
No faith in the MoBo as the SD reader does not work and I have to use the USB port and a laptop
Sounds like you just missed the M500 command, this saves settings to the EEPROM.
M500 - Save Settings
M501 - Restore (saved) Settings
M502 - Factory Reset
M503 - Report Settings
