e2160 running hot?
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
Just built a new pc today with the e2160 cpu. Installed cpu-z and speedfan to take a look at things. I'm not too clued up but I think things are running a little hot. On speedfan I'm getting reads like this on idle:
System: 36C
CPU: 34C
Core 0: 42C
Core 1: 43C
And then running an Orthos Small FFTs test my temps are:
System: 36C
CPU: 54C
Core 0: 65C
Core 1: 66C
I was hoping to overclock the cpu but with these temps I wouldn't dare! I haven't touched anything in bios, this is a clean build, as of today. My mother board is Asus PK5 and my memory is Ballistic 2GB (2x1GB) pc5400. I've got stock intel hsf and a sonata III case.
Any ideas whats going on? Does it have anything to do with the fact it's probably about 30C in my room due to ambient temps?
Yep the 30c ambient temp will be causing higher temps but I'm in pretty much the same boat as temps are very similar with my E2160 although it doesn't actually increase that much when I run it at 9 x 333. I don't have to increase any volts so that probably explains why it's not much hotter.
My Thermaltake Big Typhoon heatsink doesn't get hot at all in fact it's not even warm and I've checked to make sure it's making good contact with the CPU and it is so I'm not sure what's going on there.
ambient of 30 degrees? your house must be damn hot!! lol think my rooms about 20 degrees.
with stock heatsink mine was running near that at stock, but with a diff heatsink im running at around 65 full load @ 3.06 ghz - after bout 10 mins of orthos, seems stable thereafter at 65 ish... no hotter.
using a cheap thermalright cooler (old version of this)
Realistic temps are still hard to find with this chip i have found, as some programmes results vary by 40 degrees or more.. lol
Thanks guys. Just curious what kind of changes did you have to make to get your e2160 to run at 3Ghz? did you bump the voltage up to 1.3 and change some memory settings? Cheers
I'm using 4 x 1GB DDR2-667 with the 1:1 memory option so it's running at DDR2-667 when the CPU is at 9 x 333. I haven't changed any voltages yet but it hasn't been properly stress tested yet so I might end up having to do so if it doesn't pass Prime95.
Im on just above stock volts because of the vdroop. Running solidly at 3.0 ghz and goes up to about 56 deg C running othos. Cant fault the processor. Does superpi 1m in 20sec. Also on stock cooler.
