E2160 + Tuniq Tower temps...
28 Jan 2005
Southport
Hi all,
Just a bit of temp advice please. Ive got a E2160 @3.15 with 1.45v. Its Tuniq cooled with silver 5. I get around 66-68oC under load with all fans in my p182 full. Is this normal or should I try reseat the Tower?
thanks
Seems a little high, my E2140 runs ~63max at 3.2ghz, arent those fans deathening you ? Mine never get past low, and the tuniq towers on almost the lowest setting possible.
