hmm how far u think it will clock on the stock fan and if i plan to overclock will i need better ram? this is my current memory
General Information :
J6H1 (CHAN A DIMM 0 ) : 1024 MB - DIMM
J6J1 (CHAN B DIMM 0 ) : 1024 MB - DIMM
Information SPD EEPROM (J6H1) :
Manufacturer : Kingston
Part Number : Unspecified
Serial Number : AC32F42B
Type : DDR2-SDRAM PC2-4300 (266 MHz)
Format : Regular UDIMM (133.35 x 3)
Size : 1024 MB (2 ranks, 4 banks)
Module Buffered : No
Module Registered : No
Module EPP : No
Width : 72-bit
Error Correction Capability : ECC
Max. Burst Length : 0
Refresh : Reduced (.5x)7.8 µs, Self Refresh
Voltage : SSTL 1.8v
Prefetch Buffer : 4-bit
Manufacture : Week 12 of 2000
Supported Frequencies : 200 MHz, 266 MHz, 266 MHz
CAS Latency (tCL) : 3 clocks
@200 MHz, 4 clocks @266 MHz, 5 clocks @266 MHz
RAS to CAS (tRCD) : 3 clocks
@200 MHz, 4 clocks @266 MHz, 4 clocks @266 MHz
RAS Precharge (tRP) : 3 clocks
Cycle Time (tRAS) : 9 clocks
@200 MHz, 12 clocks @266 MHz, 12 clocks @266 MHz
Min TRC : 12 clocks
@200 MHz, 16 clocks @266 MHz, 16 clocks @266 MHz
Information SPD EEPROM (J6J1) :
Serial Number : AC32032C
Module EPP : No
Width : 72-bit
Voltage : SSTL 1.8v
Min TRC : 12 clocks
Memory Controller Information :
Memory Controller : System Memory
Error Correction Capability : No
Number of connectors : 4
Max. Module Size : 4096 KB
all on a intel 945gtp mobo
