- 17 Dec 2007
- Edinburgh
hi guys
been trying to overclock my e2180, and have been with great results
my system is as below
e2180
evga 680i
patriot 4gb ram
zalman 9700-nt
i've got it completly stable at 3.4ghz @ 1.45v's in the bios (idle's at about 45, load at about 77)
the thing is, i can't seem to get it to run at 3.6ghz. i've been all the way up to 1.625v's in the bios, and i tried upping the CPU FSB voltage and the Nvidia SSP and MCP volts with no avail.
It can boot into windows, load everything, but as soon as i try to run orthos, as soon as i click start, it crashes and last-time it jsut shut the pc down. (thermal cut kicking in??)
admitly, it was idling about 70, but surely its fine for a cpu to hit nearly 100 in orthos, as in real life situation, u will nvr stress d cpu like tht.
i have since gone back to my 3.4ghz set-up, but really want to push this CPU further, lol.
have i reached the limit of the CPU, or is my cooling my limits??
and what do you guys run your e2180's at and at what volts etc
thanks
Grant
e2180
evga 680i
patriot 4gb ram
zalman 9700-nt
thanks
Grant
needed 1.55v for 333x9
. I did it with E2200 @ 3.85ghz kamikadze shot, too bad it switched off shortly after the CPU-Z loaded due to hitting over 95c
) and that maxxed out at 56 degrees after 12 hours of prime. Cooler was a Nexxus full copper version of the Intel stock cooler but with a 92mm fan. You voltage is the cause. I noticed that after 1.4v the temps started to shoot up and with 1.5v would hit 72 degrees before i shut it down. That is why i settled for 3.6Ghz and 1.4v. It appears that you get a good one or a not so good one with these cpu's.
Did the mod and no more compensating.
