e2180 problems
17 Dec 2006
Loughborough
Just bought an e2180 and arctic silver 5 but theres already crappy stick on stuff on the stock cooler, how do i get it off?
Also how much AS5 do i need to put on?
Cheers
Theres installation instructions on the Arctic Silver website. they recommend a grain of rice sized blob vertically down the centre of the chip. You can get the old stuff off by using TIM cleaner, Methylated spirits, or Isopropyl Alcohol. Basically anything which evaporates without leaving a residue.
Where would i get a cleaner like that from?
