- 28 Aug 2003
- Portsmouth
Hi what is the default stock voltage on the E2200 chip? i.e. the voltage that it should use if you run it at 2200mhz?
I ask this because the voltage is just set to auto on my mobo when i had it at stock and CPUZ reports it as 1.3v....is this correct?
However, I did dabble in some overclocking today. I currently have mine set to 1.4v in the BIOS and CPUZ reports it as 1.376v
Speedfan detects the core temp @ 40oC
I'm running at 275 x 11 = 3025 ish
I'm using a an ASUS p5kr and this ram : OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) (Deal Product).
Is this current overclock @ FSB = 275 ok? i haven't primed anything just done SUPERPI 1mb so far.
Also the CPUZ reports on the SPD on my ram that the 400mhz settings should be 5-5-5-15. However i bought the RAM on the assumption that it would do 400mhz @ 4-4-4-15? or do i have to manually set these settings in the BIOS and also the memory voltage? (the voltage is currently 1.8v)
thanks
thanks
