E39 Air Con issue
14 Dec 2013
Hello guys,
I have a problem with the A/C on my E39 528i. Last year I fitted an air conditioning hose and a new receiver dryer canister. The system was then vacuum tested and recharged and it was working extremely well blowing ice cold air.
However now I do not seem to get cold air at all, the blower fan functions as it should but hitting the ********* button no longer produces cold air, but the revs change so I think the compressor is engaging.
I scanned the car and found a fault with the IHKA with a code of 00000A 'mixed air sensor' but no further information, does anyone know what this code means or what sensor it is? I was unable to clear the code so it is an active fault.
Any suggestions are appreciated.
Thanks.
