E39 help
28 Sep 2008
Britain
Guys, a good friend of mine has just picked up a 530i Sport Touring on an 02 plate.
Driving it back today the dash advises him that a bulb is out. He's checked all the bulbs possibly with the exception of the numberplate lamps at the rear and all are fine.
Any ideas?
Secondly, neither of the keys remotely lock or unlock the car. It recently had a new battery.
Is there a way to resync like putting the key in the ignition, turning the ignition on and pressing the button?
Failing that I guess its the batteries.
Thanks,
[TW]Fox;14752482 said:
Either the numberplate light is out or one of his rear bulbs is about to go.
Ok cool. When you say about to go, how does the car know this and could it be any of them, indicator, position, brake, fog?
Here's how to re-sync the keys: http://forums.bimmerforums.com/forum/showpost.php?p=7490182&postcount=10
I'm assuming he has the low-OBC from your description. The high-OBC will say exactly which bulb has failed.
Tourings have a habit of throwing up bulb failures from the tail lights randomly. Best thing to do is to remove the bulbs from the holders for all of the tail lights and clean up the contacts. Should sort it.
A friend had the same thing on an e46 saloon, don't know if the system is the same but cleaning up the contacts for the bulb in question sorted it
Is the high level brake light working? I missed checking this and couldn't work out why it was warning me of a bulb failure :o
I have questioned this too. Not seen the car yet. Maybe tonight. Correct me if I'm wrong though but its not high level in the 5 Touring. Its in the middle of the bottom edge of the glass, not like the E46 touring where there is a high level light along the top edge of the boot lid?
For the e46, it will be that the ground pin will have corroded. Check where the connector attaches to the light cluster.
Mine is a line of LEDs along the top edge of the glass.
