23 Mar 2009 at 11:59 #1 Sone Sone Soldato Joined 18 Oct 2002 Posts 7,882 I have got a dodgy sensor, anyone know how to swap them out?
23 Mar 2009 at 12:08 #3 [TW]Fox [TW]Fox Man of Honour Joined 17 Oct 2002 Posts 160,215 If its not one of the ones you can reach to with the bumper in situ then you need to remove the bumper. The two inner ones are the pain.
23 Mar 2009 at 12:13 #4 Sone Sone Soldato OP Joined 18 Oct 2002 Posts 7,882 its rear on the outside (passenger side)
23 Mar 2009 at 12:15 #5 [TW]Fox [TW]Fox Man of Honour Joined 17 Oct 2002 Posts 160,215 You should be able to get the rubbing strip off and it comes with that IIRC.
23 Mar 2009 at 12:17 #6 Sone Sone Soldato OP Joined 18 Oct 2002 Posts 7,882 http://forum.bmw5.co.uk/viewtopic.php?f=25&t=32939&p=807845&hilit=parking+sensor#p807845 will give WD40 a go first EDIT: it normally works after a drive but not first thing Last edited: 23 Mar 2009
