- 1 May 2006
I've OCed my E4300 to 2.7ghz and am kinda worried about the temps.
Granted, it's a warm day, but TAT reports and IDLE of 50c on both cores.
Worst still is Speedfan (which I'm not completely sure how to read):
Temp1: 54c (it has a nice flame by the temp reading, not the best of signs).
Temp2: 40c
Temp3: -2
HD0: 52c (again, a nice flame by the side off it; 52c is bloody hot for a HDD, right??:S)
HD1: 37c
Core 0: 33c
Core 1: 33c
My motherboard is a gigabyte DS3 and my gfx card is a 2900XT (yes, I know, it doesn't help the temps). the three "temp#" readings have IT8712F by them when I go into the "configure" option of Speedfan.
I have 1 92mm intake fan, 1 92mm outtake fan, my 120mm PSU fan is on max, I have a Big Typhoon on the CPU that has a hole in the ide of the case so it can have fresh air, I have also a 120mm fan on the bottom of the side panel cooling the gfx card. I assumed this would be good enough for the cooling, but the case is kinda small.
Can someone tell me if these temps are reasonable or am I verging on meltdown??
Temp2: 40c
Temp3: -2
HD1: 37c
Core 0: 33c
Core 1: 33c
I would assume if Gigabyte had thought it was a problem they would have put bigger heatsinks on em, specially when they get this warm at stock...
