easyrider said:
easyrider said:The 4300 will do 2.7ghz with ease.
Topitoff said:I read that bit, but in a Dual VSTA?
easyrider said:So see why not.
This chip will destroy a FX 62 lol on a 35 quid asrock for 140 all in!![]()
Topitoff said:Looks worth a try to me; should be better than my x2 3800 @ 2.65GHz in a Ultra D![]()
If I can get £100-£110 for the above; looks like a cheap upgrade![]()
T
beast said:Ah just realised the 4300 has a 9x multi.
BigToe said:The E4300 and 775DUAL-VSTA are a perfect combination and I can vouch for this personally.
Haven't had a lot of time to play with it so far, but I've got it stable @ 2610MHz so far (9 * 290). I set the Orthos dual core test running last night on blend mode and this morning it was still ticking away with 9+ hours of no errors. I'll probably leave it at that to be honest, it's plenty fast for me coming from a clocked Barton Mobile!
khimbar said:Haven't touched the RAM settings at all yet, I'm just running 2x512 sticks of no-name DDR 3200.
20 degrees at idle can't be right can it???
