Quick Q, using TAT what would people see as the max safest core temp, my cpu runs generally quite hot, on my ds3 with the freezer7. Havnt had v long but the thermal conductor should have hardened. Concidering replacing it with as5 though see if it makes a difference.
Oh its all inside a lian-lie pc-7 too.
@ 1.392 vcore
370fsb x8(yes 8, just testing overclock etc at the mo, trying to get a beasty one)
it goes between 71-75 at full load using TAT to test. My rooms quite warm at the moment mind.
Is this safe? It idles at about 45-50 mind. Thinking the as5 could help, aswell as possibly fiddling inside case to improve airflow and exhaust.
Oh yea, also i dont have any fan aimed etc at the chipset at the moment, but the pc7 has fairly capabale case fans as a lot of people know, is this ok for the moment? its only @ +0.1v
@ 1.392 vcore
