e4300 o/c with pc4200 ram
30 Dec 2006
Burton-on-Trent
Just ordered e4300 c2d and asus p5b mb,i already got this ram(Crucial 2GB DDR2 533MHz / PC2- 4200 Unbuffered Non ECC) and i am on tight budget so can't spend any more on ram,can anybody tell how far i can o/c e4300 with this ram any advice will be much appreciated in advance
I read in CPC mag that it can do 400MHz 4-4-4 (DDR2-800) with no problem. I also read that if you slacken the timings to 5-5-5 it can go to 500MHz+ (DDR2-1000+). I was very tempted to get some myself but instead spent a 'little' more and grabbed a set of Ballistix 333MHz/CL3
Look forward to your results, could be the bang-for-buck memory of the year.
[edit] this should be in the memory section really :)
Thanks for quick reply mate AT least there is some hope i will let u know the results one i get hold of the chip.
