I'm bunging my E4300 system into a HTPC case.
At stock speeds should be more than capable of standard HTPC use and enabling speed stepping should help reduce the power a bit.
But if I want to play games and crank up the CPU, I'd have to go in the BIOS and readjust the settings to overclock.
First question is how much am i actually saving by using speed stepping?
Second question is can i enable the overclock and still use speed stepping considering I've only overclocked to 2.7 from 1.8
Its on a Gigabyte DS3P board if it makes a difference.
It does the same in my P35 board too.
