If i remember right i seen an C1E option but i can't remember what it was set to.Cob said:Is there an EIST or C1E option?
I'll give it a try and see if it stops it, i'm sure it was disabled but it could have been enabled.Cob said:Disable C1E if it's in there.
Auto will only adjust the vcore if you adjust the FSB.
Evga 650i ultra. I've got it sorted now, it was C1E.Chris Beard said:Which mobo?
Well i've had no problems with it, which would be best to go by? TAT, Core temp or Nvidia control panel.steve258 said:I'm surprised that TAT even worked on your mobo?
Thought it doesn't support nvidia chipset, well it doesn't work on P5N-E anyway.
TAT 45/43 Core temp 28/28steve258 said:I'd trust TAT & core temp tbh. Both are not 100% accurate but are close enough to real temp.
. Big difference.Yes, also Speedfan 4.32 says about same as Coretemp and Nvidia control panel... so only TAT that is quite high.Jokester said:You using the most upto date Coretemp?
Jokester
