Will a E4300 perform the same as an E5200 given that the E4300 is overclocked to the stock speed of the E5200?
E5200 performs marginally faster clock for clock I believe, also since it's 45nm can oc higher on average.
Have a read of my review comparing the E4300 and E5200 (and others) at various speeds.[/QUOTE
Thanks, seems that keeping my E4300 and pairing it with a good mobo/RAM woul
be my best option.
PC2 6400 is more than enough for a E4300 so it's just the board you really need. The ram would get you to 3.6Ghz before it went over it's specced speed. You are not going to get that high with a E4300 anyway.
If you can find one, a gigabyte P31-DS3L or similar variant. that chipset punches well above it's weight as it were and they're gonna be cheap "IF" you can source one as they're not made any more I believe![]()
