2 May 2008 at 14:29 #1 DAnDan DAnDan Soldato Joined 22 Feb 2008 Posts 4,473 Hello all, I have just got my E4500 to 3.2Ghz (400*8) and appears to be stable at 1.440V (reading from CPU-Z). Is this voltage safe for consistant use? Core temp is reporting temps of around 22c idle, and around 55 under orthos.
2 May 2008 at 14:36 #2 roadie roadie Soldato Joined 22 May 2003 Posts 2,884 Location Wiltshire Sounds fine. I just received an e4500 and am looking to hit a similar speed, what cooling are you using?
2 May 2008 at 14:41 #3 DAnDan DAnDan Soldato OP Joined 22 Feb 2008 Posts 4,473 One of these coolers - http://www.overclockers.co.uk/showproduct.php?prodid=HS-024-CM&groupid=701&catid=57&subcat=821
2 May 2008 at 19:35 #4 Vir Vir Associate Joined 21 Oct 2002 Posts 1,860 Location Netherlands That is just fine don't worry Good temps, you are all set!
10 May 2009 at 02:41 #5 MrMoses MrMoses Associate Joined 23 Dec 2008 Posts 314 Location UK Wtf I get 3.3Ghz with 363x 9.0 Multi on 1.34 Vcore Maximus Formula Ha ha
