E46 330Ci auto box ok??
There is changing the oil, which in my opinion can only be a good thing.
Then there is flushing the gearbox which i can see has the potential to dislodge crud and do more harm than good.
[TW]Fox;18272419 said:
Half the people on the internet thinks the box will fail after you change the oil, the other half think the box will fall if you dont change the oil.
I think half of the problem is the two different gearboxes and the fact they both suffer from a no reverse issue, but completely different problems causing it. On the GM box it's caused by a mesh part in a solenoid becoming gunked up, whereas the ZF box has a much more terminal problem of the reverse drum disintegrating. I bet a lot of the people who have had their box fail after an oil change/flush have the GM unit.
[TW]Fox;18270113 said:
No, BMW just renamed the trim level, if you buy a 54 plate it'll be an M Sport, if you buy a 53 plate it'll be a Sport...
It was just a genuine question as I see this in the car park everyday...so one would assume that it's stick on tat or something? :confused: :o
And yes the photos are very twoblacklines. :D
That is a 330Ci Sport, with an M badge stuck on where it used to say 330Ci. The 330Ci M Sport doesnt have a badge like that either.
