e46 Bluetooth OEM?
23 Oct 2004
Brighton
Howdy.
Picked up a 330 touring today, came with a telephone booklet and pairing code in the docs.
Has a little stubby antenna on the roof, and a microphone near the sunroof controls. No Phone button in the centre arm rest tho...
Also has a antenna connection box thing in the boot.
Spec sheet says "Prepped for phone", so am I missing some modules?
Would be nice to use the car system, and not bolt in an after market contraption.
Anyone know about these things?
Ta.
[TW]Fox;28451606 said:
Sounds like it has Bluetooth but with an old UIM that doesn't work with modern phones.
Could be, it is a '05. I have seen a connector in the armrest under the coin holder. I was expecting a button somewhere to do the pairing - seeing as the manual and code leaflet point towards a pairing operation. Also no silver box in the boot.
If it has a coin holder and cup holder in the centre then it could be that a previous owner swapped out the phone cradle with Bluetooth button so you'd just need to source a spare for the purpose of pairing.
Found code s644a "Preparation for phone with Bluetooth"
Could it be as easy as adding a button to start the paring?
It's certainly a possibility, yes. Just take your cup holders or centre tray out and see if the connector is there before buying a cradle.
Ok.
Found a BMW bulletin that apparently says to disregard the user manual and bluetooth code as my car build date has a non bluetooth unit.
I do have a BT device in the car somewhere, but it does not have a name just a MAC address. Can't connect to it either. Maybe it does have BT just no software to run it. I did read about that somewhere.
S.
If it doesn't end up having Bluetooth, get hold of a parrot ck3000 evo. It integrates almost seamlessly with the car, providing you 90% of the same experience as the oem unit.
Tried the paper clip trick between pins 1 and 17. Paired and can get my contacts on the car. So far it looks like it is working :-)
