6 May 2013 at 18:04 #1 kash786 kash786 Associate Joined 9 Nov 2010 Posts 249 Location Leicestershire Has anyone had this issue before with door seals on a '04 E46? Is it a known issue? What would anyone recommend to seal it back up? (apologies if the image is a bit big, cannot resize as I'm on my phone!)
6 May 2013 at 18:43 #2 prj1865 prj1865 Associate Joined 8 Sep 2012 Posts 374 Yep I've had exactly the same on my 02 e46. I just used whatever glue I had in the house and stuck it back on.
6 May 2013 at 18:48 #3 acemastr acemastr Soldato Joined 29 May 2010 Posts 4,737 Location Tampa, Florida My rubber seal has split and broken, ridiculous money to buy a new one though!
6 May 2013 at 18:49 #4 Atari Atari Soldato Joined 31 Jul 2003 Posts 3,678 Location Somewhere far. Mine had this problem. BMW charge a silly amount of money for it. I used some glue I had lying around (Evostik or similar iirc) and it's not come apart since. Make sure both surfaces are perfectly clean though
6 May 2013 at 22:38 #5 Fantom Fantom Associate Joined 13 Feb 2006 Posts 2,445 Location Cornwall Get sticking, common problem from what I can see!
