E46 Spark Plug change - How often??
Every Inspection 2. This is condition space but generally around every 60,000 miles or, potentially in the case of low mileage drivers, 8 years.
how much are spark plugs for 320i's ??
for me,
dealer(motorcraft) - £40
halfords(ngk) - £20
halfords (bosch) - £11
guess which ones the ocuk resident ***** bought? :p:D
60,000 miles that is amazing this proves that i am being excesive changing mine every 10K on the pug 2.0L 307 and every 4k on the bike SV650.
That's quite normal when using platinum spark plugs....you do pay a bit extra though.
Mine were £35 iirc for the vrs. Every 10k on the 307 isn't excessive if you only use the copper ones (a lot cheaper but don't last as long).
