Furthest i've pushed my e5200 so far, had it running at 3.33 for ages but fancied a change. Unfortunately my board - g31-es2l has limited memory options (+0.1,.2,.3,.4) so i'm not entirely sure on the next step.
I want to get 3.5ghz stable do i just have the ram at .4 and let it rise with the fsb? (ram is corsair 1066mhz). in terms of volts how far should i go, i've tried 1.36v and that failed to boot, how much higher is safe? Temps are good so no worries there.
Edit - 3.4 - 1.3v
i wouldn't mind getting 3.5ghz but after hiking the volts up from 1.3 to 1.36 i can't get it to post.
