E5200 alternative coolers?
11 Oct 2008
my current stock e5200 fan is ridiculously large at the base and is touching pretty close to the north bridge heatsink. Can anyone recommend a third party fan. something not too expensive, under £40-50 ?
Thermalright ultra exteme can be had for £37 delivered, may get your 5200 to 4ghz
or a good budget one is the Xigmatek HDT-S1283 £20-£25
Arctic Cooling Freezer 7 Pro although i would'nt get it from here due to the price. I have one on my E5200 and it's clocked at 3.6Ghz. You don't need a stupidly expensive cooler for one as they are a cool running cpu.
Is it touching or not? Are you sure that the stock cooler doesn't fit on the motherboard? That sounds a bit odd to me. What motherboard?
Also, if you're happy with the actual performance, why bother upgrading?
I've just ordered a Noctua NH-U12P for my e5200 to replace my ageing ACF7 as it's getting noisey. Still cools well though.
Noctua > * for build quality.
its really close, not physically touching but the stock cooler is too noisy even at 60% speed. just looking for something a bit more narrower and quieter.
btw my mobo is an asus p5kc
http://www.overclockers.co.uk/showp...cket 775) PCI-Express DDR2 & DDR3 Motherboard
The cpu isn't worth much more. :P
Arctic Cooling Freezer 7 Pro seems about right for this, buying a cheap processor and sticking an expensive cooler sort of defeats the object.
i have a e5200 and it runs at about 65c @3.75ghz
Well you say that, but a decent cooler will outlast many a cpu if you upgrade often, a decent heatsink will take any CPU you throw at it where as a cheaper one may not, so it'll work out even more expnesive because you had to buy two.
But I can vouch for the ACF7 being good with the E5200, at stock mine idles at 25 and 30c.
well if not swapping to nehalem anytime soon then it would be a good idea as many a socket 775 cpu will be avialable for upgrades at bargain prices
Intel Core 2 Quad Extreme Edition QX9770 probably be able to pick that up in a year or two for peanuts
