I've got a few questions regarding overclocking this chip.
I recently picked one up from here, and had a quick play with it last night for an hour or so.
Given it's a pretty cheap chip, I wouldn't be *too* upset if it got fried, and so did a few reckless overclocks.
I got it to 3.5Ghz at stock volts, but wanted to see what it would take to hit 4.
I tried 1.4v and then finally got prime95ing at 4Ghz with 1.425v. My temps were showing at around 58C under load (I'm not sure it was reading correctly - I heard some of the temp sensors on these chips are faulty?).
I think I could probably nudge the voltage down a bit, but bearing in mind that it's a 45nm chip, is 1.425v excessive for everyday usage using an air cooler? (freezer 7 pro)
What is an acceptable idle/load temp?
me thinks i got a dud lol.
