E5300 voltage help
15 Jul 2009
just built a pc for my daughter would like to know what voltage settings stock voltage settings can be used on an E5300 processor im using a gigabyte mobo and what temps under load prime 95 should i find exceptable....
The E5300 will quite happily run at 1.2v. Im using that Voltage at 3.5ghz and its still stable.
Anywhere upto 60c I would say is a good operating temperature. Although its quite a cool running chip, Never seen mine go above 40 but I do have mine under water.
