- 10 Oct 2006
- Chichester
Thought that I might try and see if you chaps could shed some light on what may be causing my bosses E60 to lose battery charge (sometimes overnight.
First his car:
It is a E60 5.30 D se with full Schnitzer body kit (and some dodgy wheels) as found here: (can't upload a pic from here so hopefully this will do)
http://www.madmotors.co.uk/catalog/nev-hoults-bmw-e60-p-22501.html
Symptoms:
Loses battery charge overnight, with the colder weather highlighting the problem.
Fans blow but stay at the same speed regardless of input, and run even after they are switched off although not after the car has gone into sleep mode (though he hasn't checked in the dead of night to see if they are activated).
Active power steering resets or doesn't work at all until he has driven the car for a mile or two.
CD/DVD can be heard changing the cassette even though the car may be switched off.
Transmission warning light comes on.
Headlights flash when the car is turned over.
Some of these may be a symptom of a flat battery rather than a fault.
The car is on it's third battery and he has had this charged and it isn't holding. His BMW dealer are insistant that there is no problem and he even had to pay for the new batteries even though they were in warranty as they said there was no fault. Alternator is tested as working fine.
I have searched around and found that the FSU, Final Stage Unit. AKA, Blower Motor Resistor can fail and cause or be the cause of the problems as can be found here:
http://www.bimmerfest.com/forums/showthread.php?t=247697
http://www.pistonheads.com/gassing/topic.asp?h=0&t=626389&nmt=e60
Before I suggest this to him, does this sound about right or anybody have any other ideas. Thanks for input.
First his car:
Symptoms:
