I managed to get my e6300 stable at 3.5ghz (7x501) by swapping the Gskill6400 in my sig to 2GB OCZ PC8500. It turns out that the cpu was limited by the memory.
However the temps are 66 degC under load and 55 degC idle. This is with a vcore of 1.45V in bios (1.408V in CPU-Z).
are these temps acceptable or too high?
The system is bootable at 3.67ghz (7x525) but not very stable even if vcore is set to 1.5V.
although I still don't think i'll use it for 24/7 usage.
