Righty, was going to sell this on as i have an e6600, but though't i'd have a little play after seeing it was a L628B stepping, booted up fine, running a zalman 9500 with mx-1 paste, idled at 35c and loaded to 45c (this room is VERY hot, gets the sun all day long) so i was fairly happy with those temps.
Went into the bios and left everything on auto except the memory fsb was on unlinked (at 400mhz 4-4-4-12-1T)
Upped the fsb to 300, tested for 30 mins, great, no problems, temps maybe 1c higher than at stock, back into the bios upped fsb to 333, 30 mins of orthos was fine, but the temps jumped crazily... 50c idle and 67c load
cpu-z was reporting the voltage at 1.126v.. about right for stock with loaded vdroop.. (stock appears to be 1.25v on this chip...) checked temps with coretemp, tat, speedfan, pc wizard, all the same... went to the bios' hardware monitor to check, they were the same too... but it now said the voltage was 1.4v surely the board doesn't adjust the voltage when overclocking???? (it was on auto, rather than manually specifying it..) anyone else had this?
Anyway, manually set it to 1.325v, tested, temps are now 38c idle, 50c load.. happy with that
Back into the bios, 366mhz fsb, tested, fine... 400mhz fsb, tested, fine... 433mhz... thesting now, and so far is fine after 30 mins... damn this is a nice chip.. would love to hit 533mhz for that loverly 100% clock
Just wondering how other people are getting on with this stepping?
Will keep y'all posted..
Cheers,
Phil
cpu-z was reporting the voltage at 1.126v.. about right for stock with loaded vdroop.. (stock appears to be 1.25v on this chip...) checked temps with coretemp, tat, speedfan, pc wizard, all the same... went to the bios' hardware monitor to check, they were the same too... but it now said the voltage was 1.4v surely the board doesn't adjust the voltage when overclocking???? (it was on auto, rather than manually specifying it..) anyone else had this?Anyway, manually set it to 1.325v, tested, temps are now 38c idle, 50c load.. happy with that
Cheers,
Phil
