Right, I have a Core2 Conroe E6300 running on a Gigabyte GA-965P-DS3 with a freezer 7 pro rev2. Ive got it running on stock volts at 2.24Ghz. However, I've tried to bump it up to 2.4Ghz but it just doesn't seem to want to play ball. I've bumped the ram by plus 0.2V and bumped the CPU up by a couple of notches in voltage options. It barely gets past the first few seconds of POST at 2.5 Ghz and windows throws up a load of errors at 2.4Ghz.
It just seems weird to me that it's crapping out such a small push later, despite a boost in volts. Prime95 chucks up no errors and heat is fine at 2.24Ghz. That and I'm pretty sure this chip can do better with this setup.
Also, I accidently left PCI EXpress frequency at Auto instead of 100 when I tried for 2.5Ghz. I realised abotu 20 seconds in (computer didn't boot properly anyway) and reset the machine to change the setting. Is there a chance I could have damaged something?
Jsut looking for soem advice as why it's not going that far? This is my first overclock so these are baby steps for me and I'm not 100% sure on what to expect.
. Gonna give the ram a thorough going over to check for errors.
