I have just built the system in my sig and have overclocked the E6300 to 2.8GHz for now. The problem is that the cpu coretemp seems to be pretty high. At idle it's about 54 Deg C and shoots up to around 63 Deg C under load. The wierd thing is that my old PC shows a motherboard temp of 30 but this shows 39 Deg C in the same room. Room temp is around 24-27 Deg C.
I have updated to the latest bios and can boot into windows at 3.09GHz (7x440) and run benchmarks but the temp starts to rise quite alarmingly. At 3.09GHz the temp reached 69 Deg C under load!!
At the higher clock speeds I have to increase the core voltage to 1.41V.
What bothers me is that even at stock speed the temp is rather high (46 Deg C idle, 52 Deg C Load). I thought the Scythe Ninja was supposed to be one of the best coolers.
Anyone any suggestions on how to bring the temps down?
*sorry about sig.
*sorry about sig.
