E6300 installed and running, a little help setting up please.
27 Dec 2003
UK PLC
Spec is E6300 at stock.
2 x 1 gig Geil value
P5NE-sli mobo
What programs do i need to stress test, measure temps of both cores (speedfan is saying 16C with water), make sure both cores are enabled and that sort of thing.
Once thats done and ive cleared away the mess its OCing time.
Cheers
Intel Thermal Analysis Tool(TAT) for temps and orthos for stressing seems to be most common.
i'v just built a similar system but arround a DS4 so i'll look forward to your results. :)
run 2 copies of orthos small ftts, open taskmanager,system performance kick 1 copy of orthos in, cpu usage should go to 50% then fire the other copy of orthos up cpu usage should jump to 100%
i use core temp to monitor temps
stinka
stinka
With orthos beta you only need to run one instance. :)
Ive run with 1 and 2.
Im at 2.8 at the mo but Speed fan is reading a bit odd, my CPU is at either 17 or 22C, these are the only temps that i cant account for. :confused:
I do have a decent WC set up though.
TAT doesnt work on the P5N-E sli because it is an Nvidia board and not Intel. You need to use Coretemp to get accurate temp readings of the cpu.
Coretemp is saying 36C on both cores an hour into Orthos.
What is the 'T junction' Temp? mine says 85C.
Im testing at 3.1 on 1.5V, Chipset still on auto.
T Junction temp is the MAX you wanna see them cores at! I read somewhere.
Edit
Tried to find where I read it but it alludes me
TAT works from the cpu not the board its running on - if its an intel cpu it will work.
Now ive hit a snag, no matter what i try to run the FSB at in the bios, it reverts to 1826 (just under 3.2ghz).
Is it cos the RAM is not linked by any chance?
Temps are fine
3.1 run 5 hours Orthos no probs.
wizardmaxx said:
I had to use the easytune software to get my 6300 over 3.2Ghz. Does your mobo come with overclocking utility.
No, are you running the same mobo as me (P5N-E SLI), im sure it will hit a higher FSB than this :confused:
wizardmaxx said:
No I got the DS4. Pushed the 6300 to 3.4, but can't seem to get to 3.5
Seem to have got past it now, im at 3.25 and gonna test for a little while.
Ive still got the chipset volts on auto and the temps during Orthos are mid to high 30's. im hoping for 3.4 and i'l be happy.
*EDIT*
now on 3.3 and 39C in Orthos.
I'l be happy at 3.4 stable then look to bring the RAM up.
If im stable at that i'l go for lowering the VCore (1.4+1 atm)
