Aww easyrider. *hugs*easyrider said:Notice that my 3.5ghz had scope for tweaking for 12 hrs stabilty.
And 3600 does not.
Well, there isn't really any need to shout anyway.easyrider said:FOR MOBOS THAT HAVE NO FSB LIMITAION THE E4300 IS NOT THE CPU TO GET,
THE ONLY TIME A E4300 IS USEFUL IS FOR MOBOS WITH LIMITED FSB.
Sorry for shouting but i have said this so many times now its getting boring!
Kaiju said:Well, there isn't really any need to shout anyway.
If people want the info offhand without scourining thread by thread for a specific answer, then they have every right to do so. If you don't have the patience for people who want an answer straight away without having to do any research (probably as they are busy people), then i suggest you refrain from the the thread and keep your knowledge to yourself.
It's *called* show a little common courtesy mate.easyrider said:Its called the search function.
Kaiju said:It's *called* show a little common courtesy mate.
Yeah, that's great and all, but why post a shouty type reply to someone you don't have time for?easyrider said:I'll give time to people that want and indeed have interest in the world of pc.
Kaiju said:Yeah, that's great and all, but why post a shouty type reply to someone you don't have time for?
If you don't have time for said person, why don't you just not post at all?
easyrider said:Its not personal.
Its for people in general.
The GFX card forum is in a state at the mo with the same posts about the 8800 gts 320 mb.
is faster than this?
should i upgrade from this?
how much faster is it than this?
will my psu power the 8800 gts?
it goes on and on and its making the borads bland!
Glad now that I stated the the awswer with a bit of volume as now the OP has got the answer he needs.
The problem is that people cant make sense of this! Ive received conflicting information on this very forum, people saying that the E4300 may overclock better as it is at a lower FSB anyway so the memory wont be a limiting factor especially if you have decent ram. But then other people say get the E6300 or E6xxx as your more likely to overclock to above 3ghz but you need a decent motherboard and overclockable ram as your going to go to high fsb's above PC6400.easyrider said:FOR MOBOS THAT HAVE NO FSB LIMITATION THE E4300 IS NOT THE CPU TO GET,
xiphrex said:The problem is that people cant make sense of this! Ive received conflicting information on this very forum, people saying that the E4300 may overclock better as it is at a lower FSB anyway so the memory wont be a limiting factor especially if you have decent ram. But then other people say get the E6300 or E6xxx as your more likely to overclock to above 3ghz but you need a decent motherboard and overclockable ram as your going to go to high fsb's above PC6400.
So why would the E4300 be worse at overclocking when its originally at a lower FSB? Surely its easier to overclock! I mean I seen some reviews and they all say it is the chip for overclocking at the moment as they managed to get 3.2ghz easy and go further. Plus some people managed to get this aswell.
Isnt the E4300 also made with a smaller process so in theory will produce less heat and need less volts? Ok sure it doesnt have half the cache deactivated like the E6300, but why would that make a difference?
It just doesnt seem logical, and thats why people like me struggle to understand why I have to get better ram and a better mobo just to get what I could get with a cheaper setup. Anyway we'll see what happens next week when my E4300 comes in, I guess I have to try first see if maybe I get a decent chip!
