Hi,
first of all, this is using the spec in my sig.
I had my first experience of overclocking the other day and managed to get my e3600 to 2.8ghz (400x7), I chose this as it was easier to keep my ram at its rated speed to start with.
also i have read that going either side of 400fsb changes the strap you use which reduces performance to some extent (i dont really understand straps!)....
Anyway, after getting a successful overclock to 2.8ghz i tested it using the futuremark programs and this is what i got...
Standard clocks
3Dmark06: 5127 Better
3Dmark05: 9948 Better
PCmark05: 5689
O/C to 2.8ghz
3Dmark06: 4303
3Dmark05: 8447
PCmark05: 6301 Better
As you can see, although i saw a good increase in genral performance (PCmark05), I saw a very substancial drop in 3D performance.
My question to evreyone is.... WHY ???????
has anyone else experienced this drop ??
Also i noticed a slight drop in framerates in realtime game playing using fraps. I was under the impression overclocking my rig would make it awsome... not the opposite !!
can anyone help ?
Thanks
Arge
AVOID A 360-399MHz, 401 and 401-460MHZ FSB AT ALL COSTS. If you intend to overclock, get PC2-8000 and push for 475+ for high CPU clocks, or settle with a 400x6/7/8/9 clockspeed depending on your CPU for maximum performance. Not following these guidelines will not only rake your memory bandwidth over the coals, but also introduce SEVERE instabilities as the chipset (Northbridge) tries to run at too great a clockspeed.
Standard clocks
PCmark05: 5689
O/C to 2.8ghz
3Dmark06: 4303
3Dmark05: 8447
can anyone help ?
Thanks
Arge
