- 4 Nov 2006
Ok, so I followed Duke's overclocking guide found at http://forums.overclockers.co.uk/showthread.php?t=17610180
He stated on number 5 of the overclocking guide that:
"Enable CPU Host Clock Control and increase the FSB (default 266). Depending on your chip and ram, you will need to keep an eye on the System Memory Multiplier. Make sure your ram is still running the correct speed after increasing FSB. In the screenshot below you can see I've set mine to 2.0 which means my ram is running just under it's default speed (800)."
I did this, clocked my CPU Host Frequency to 400 and my Memory Frequency is running exactly 800 Mhz. This results on my E6300 to run an exactly 2.8Ghz. However, I saw some people with E6300 reaching 3Ghz and beyond. How can I achieve this? Can I increase the CPU Host Frequency and go beyond the rated 800 Mhz speed of my ram?
I have the Gigabyte DS3 mobo and 2 x 1gb OCZ pc6400 ddr2 ram
RAM is your divider
