E6300 Overclocking.
20 Oct 2002
North West
Well I've disabled all of the gubbins and it's stable for 8 hours in orthos at 2.8. Now when I raise ram to 460 @ 2.2v/[email protected] it crashes in orthos after 1.5 hours. It also crashes with 1.4125 @ 430fsb (after 4 hours). I have MCH+.1 and over voltage set to +.1 :/
Edit: Whoops, I've only orthos'd at 2.38ghz which I left for 7 hours, so 2.8 may not be stable - but I'll guess it is :p
What speed is your memory at stock? What are the timings set to? Are you running your memory on a divider or is it set to 2x in the bios? Try loosening the timings as this is what caused Orthos to crash for me after a few seconds.
Robert said:
Timings where on auto and my ram is Geil PC6400 ultra DDR2. My multi is 2* in the bios.
Try the timings at 5-5-5-12 or if that doesnt work then try 5-5-5-15. Look at my sig, we have very similar setup, my RAM is set to the latter of the above timings @ 920Mhz (460Mhz) and at 2.2v
