E6300 Stock VCore
It's also shown at the bottom of the voltage adjustment list on Gigabyte motherboards. Underneath where you adjust the VCore.
You won't know what Vcore is necessary when overclocking till you actually get round to clocking the chip. That is so long as it's a chip that you're unfamiliar with, from a batch you are unfamiliar with. You're best waiting till you have installed the CPU.
Most of these CPU's run at varying voltages. I've known someone using an E6300 with a VID of 1.325V, while mine has a VID of 1.250V. Some have had 1.225V, for example. It varies.
