E6400 @ 3.2ghz with ninja cooler and 60oc load temp?
Permabanned
13 Nov 2006
does this sound about right. At stock voltage?
This is using intels tat which reports like 10oc higher than any other. Also using the load option in that program. think its about 50oc with orthos running full load.
urm that's higher than normal, i too have a 6400 @ 3.2ghz mines on stock volts but only has a TT typhoon and i'm pretty sure contact isn't brilliant!
i idle at 37&39c (each core) and load 49&50c during orthos
