E6400 50C load @ stock?
6 Nov 2005
Aberdeenshire
Is that not a bit too hot considering it's under a Scythe Ninja and the case has 3 120mm fans on it.
I'm thinking i may have to reapply my AS5, perhaps it didn't seat properly.
I was using coretemp to monitor temps, and Orthos dual prime to stress.
running stock volts at the moment to till I bed it in. Just built it tonight.
:rolleyes: haha omg i'm such a nooob!!! I forgot to plug the 120mm akasa amber fan that's attached to the Ninja in!!! :rolleyes:
Damn 50C isn't so bad for being passivly cooled then
Just plugged it in and will try priming again.. once the fan has a little time to do its job.
im running a e6400 @ 3.2 with 1.4v on my scythe infinity and my temps are only 34-36 using core temp, surely yours should be better than that.
*edit* sorry just realised yours id under orthos.... silly me. :D
