e6400 and ds4 clocking help
Each and every chip is different, so there's no way to say how far it will overclock. Tho 3.3ghz should be possible if it's a half-decent chip.
Set the FSB and MCH voltages to +0.1v, whack the CPU voltage upto 1.425v, set the Memory Multiplier to x2.0, set the correct memory voltage, and see how far you can push her.
ok cheers well i just thi secound only changed the fsb to 380 i think and it went to 3ghz so then i did the cpu voltage and mch change and when i saved the settings and the pc made a noise at the start up and its all gone back to stock speeds
btw whats best correct memory voltage Corsair 1GB DDR2 XMS2-5400C4
Give it a bit more FSB voltage. Might need some more CPU vltage, but watch your temps.
Eeek that's toasty.
See if you can drop the CPU voltage a bit. If you can't then you'll either need to drop the speed or invest in a new cooler.
yes well the fan on the pc is kinda on low i forgot what program i need to speed it up
just lower the cpu voltage and its idel 53c
Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz
CPU speed: 2759.91 MHz
CPU features: RDTSC, CMOV, Prefetch, MMX, SSE, SSE2
L1 cache size: 32 KB
L2 cache size: 2048 KB
L1 cache line size: 64 bytes
L2 cache line size: 64 bytes
Prime95 32-bit version 24.14, RdtscTiming=1
Best time for 512K FFT length: 9.718 ms.
Best time for 640K FFT length: 13.097 ms.
Best time for 768K FFT length: 16.205 ms.
Best time for 896K FFT length: 19.141 ms.
Best time for 1024K FFT length: 22.256 ms.
Best time for 1280K FFT length: 27.224 ms.
Best time for 1536K FFT length: 33.121 ms.
Best time for 1792K FFT length: 39.306 ms.
Best time for 2048K FFT length: 43.718 ms.
Best time for 2560K FFT length: 57.820 ms.
Best time for 3072K FFT length: 70.464 ms.
Best time for 3584K FFT length: 83.858 ms.
Best time for 4096K FFT length: 93.999 ms.
Best time for 58 bit trial factors: 4.077 ms.
Best time for 59 bit trial factors: 4.080 ms.
Best time for 60 bit trial factors: 4.063 ms.
Best time for 61 bit trial factors: 4.082 ms.
Best time for 62 bit trial factors: 6.465 ms.
Best time for 63 bit trial factors: 6.492 ms.
Best time for 64 bit trial factors: 6.197 ms.
Best time for 65 bit trial factors: 6.154 ms.
Best time for 66 bit trial factors: 6.185 ms.
Best time for 67 bit trial factors: 6.162 ms.
doing some stress test and max temp it goes to is 56
