e6400 overclocking
6 May 2003
stoke on trent
having hit a wall guys not sure if im doing something wrong :s
system specs:
e6400 2.13 @ 3ghz
G.Skill 2GB DDR2 HZ PC2-6400C4 @ 750
asus p5w dh deluxe
the problem i have is i cant seem to work out away of getting 800+ mhz from ram without lowing fsb speed/cpu.
and was woundering am i missing some setting here or something ?
all at stock volts.
set ram to 1:1 400x8 = 3.2 ghz and 800 mhz ram and so on.
If no work try 401 x 8 and so on it may be a fsb hole.
tried that didnt work even tried upping the cpu/ran voltage with no luck :(
hope its not memory holding me back as before as ive just got some new :S
fsb currently at 1501.8
any 1 know how to change ram divider on asus p5w dh deluxe ?
can seem to change it from 1:1
errm looks like my board needs a x9 multiplyer
FSB Wall at low fsb around 300 - Disable Hyperpath 3 in the Chipset section of the bios. [Credit - lawrywild]
Quote:
Originally Posted by cmthomson
The issue is that the P5W DH normally overclocks the 975X NB by changing its strapping from 1066 to 800. This gives better benchmarks at stock speeds, but limits the FSB speed. This feature is controlled by the "Hyper Path 3" BIOS switch; disabling this forces the 1066 strap and allows much higher FSB speeds without overvolting the NB.
FSB Wall at around 360-370 fsb - Enable SPD timings option in Chipset section of bios.
http://www.xtremesystems.org/forums/showthread.php?t=110193
i allready had those options turned off.
but it seems the only way i can get it to run stable at 400/3.2 is to max out the mch voltage.
allso what is the so called safe voltage of a e6400 ?
read that post link in full you have a fsb hole.
i wouldn't go much above 1.5 volts to be safe unless you are sure.
