- 10 May 2006
Hey all,
As you might know, I have a few temperature issue's with me E6400. Today I came on the lavalys site and saw they released a new everest with C2D Support. I quickly downloaded the new version and checked the temperatures. I have EIST enabled, so temps are normal a little higher, this is idle:
http://img208.imageshack.us/img208/5031/wtfph1.jpg
How the hell can the cores be 40C and CPU 24? Seems like a bad contact bitween the cores and IHS ?
Also, my I use stock cooling w/ AS5, reseated a few times, didn't help. Cores 1 and 2 get around 60C stressed, not overclocked.
Also found this?
http://www.lavalys.com/forum/index.php?showtopic=1839
So how much can the core temps be? and what should i trust ?
A friend of mine got is E6400 running @3ghz stock volts, if I remember correctly on a scythe infinite, stressed it doesnt come above 50C TAT/Everest!!!!!!! (the cores)
Also found this?
and oc'd to 3.2, drops to 55~ under load with full rpm of fans.
