- 12 Apr 2004
- Somewhere
E6400 temps... too high?
I'm getting a bit confused about CPU temperatures at the moment... I'm running my E6400 at almost stock frequency (2.4GHz as opposed to 2.13GHz with VCore at 1.325V), but the temperatures are at around 45/46ºC according to the BIOS.
I've got 2 80mm exhaust fans at the rear and top of the case, 2 intakes at the front, a 120mm fan on the PSU, and an extra exhaust fan at the bottom which fits into a card slot. The CPU has an Freezer 7 Pro on it as well, so I shouldn't be getting temps that high at such a low clock should I?
The most confusing thing is that every program I've tried in XP gives me different readings:
BIOS - 45-46
ASUS PC Probe II - 41
SpeedFan - 36 (this is the same as the MB reading on PC probe)
Core Temp - 30-32
Which one can I trust?
BIOS - 45-46
Core Temp - 30-32
