Hey guys, i have overclocked my E6420 to 3.2Ghz (400 FSB) 1.45 Volts and running the Memory at 800Mhz 3-3-3-12 2.25 Volts, evertyhing is fine.
Specs in Sig.
Now the max FSB i can get the computer to post at is 423, anything higher than this, it will just not post at all.
I have just been reading the overclocking sticky again, the part where it saids to determine the max FSB, lower your multi to find this out. So i lowered the Multi to 6 and began working my way up. I get to 423 everything is ok as soon as i change it to 424 and restart it and it just wont post. Am i right in thinking thats the Motherboard thats causing this? That will be a real shame if it is, i know that the ASUS P5B Deluxe can go much higher than that.
Hope you guys can help.
Specs in Sig.
